quote:Originally posted by Topless in Cali
I do have the denso's so that's why I tried it. Have not gotten any codes yet but you never know. Thanks AZ for the info. I think I'm going to get new plugs now that I've got S1 on order along w/ 3" o2 housing. What $$ is AGP getting for thier modified plugs? I haven't decided what to get yet.
The 3" o2 housing won't help that much really, and its really tricky to not get any exhaust leaks in that area once you break the seal there. Just get a 3" downpipe and flow through exhaust, and you will see the same gains and not worry about leaks. the agp plugs go for about $100 whick includes the wires, remachined shorter plugs and the socket you need to put them on. [^]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\">  </div id=\"right\">
