Old 29 Aug 2005, 05:57 am
AZ_IceMan AZ_IceMan is offline
Send a message via AIM to AZ_IceMan
Not necessarily. Could be that you just got a bad batch of gas, I don't go to QT anymore by the way. I drive around and look for a shell or chevron station. Maybe the occasional mobil. But anyhow, also did you check your spark plugs? if the gap is too open then yes, at high rpms you would ping. [V]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
