there is a gasket there, you are going to have a hell of a time getting the stock downpipe off though. The very top bolt, the one you can't see and barely feel has a lock washer on it. I had to cut the bolt off while it was still on the car with a dremel cutoff wheel. [B)] needless to say, this stupid bolt made an extra 3hrs work for me. but now i know, and you do too. Not sure on the O2 sensor question though.
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\">  </div id=\"right\">
