Old 05 Sep 2005, 07:13 pm
2step 2step is offline
If I understand your question, you will need to run an additional wire from your front, side marker lights for "constant on" or from each turn signal light for "blink" with turn signal. The stock mirror harness doesn't have switched power for lights.
If your directions for the new mirrors don't indicate which wire is for the mirror LED's, you may have to test each with 12 volts.
On a difficulty scale of one to ten, this is a Five.
