Old 06 Sep 2005, 01:45 pm
comPuTer comPuTer is offline
quote:Originally posted by SuGamer
Check the balancing of the tires. If a weight fell off, it would cause a vibration in the wheel, usually noticeable at certain speeds. If not, then check the bushings and control arms. Next, with the car up (wheels just hanging) and car off, push and pull the tire sideways to check the tierods then push and pull the top and bottom to check the ball joints. Do this for each tire. If everything comes out right, then it most likely is one of your axles is bent, even if it's unnoticeable.
I agree with SuGamer's advice. Start with the balancing. I would suggest getting the wheels "statically balanced" rather than using the standard rim-mounted wheel weights. The static weights use adhesive and are mounted inside the wheels, which keeps your wheels looking nicer (no weights are visible). I've had mine using these for more than a year and I really like it. The price for balancing should be the same.
