Any lowering springs NOT bottoming out???
Anyone out there that has installed lowering springs and has not had the bottoming out problem? I was all set to order a set of Eibachs but it seems even with the progressive wound springs most people have posted bottoming out or bounce problems...maybe I should just go with aftermarket sways to cure the "lean" in corners...
Do you only bottom out when carrying passengers? 99% of the time its just "us" so maybe bounce wouldn't be a problem [:I]
Thanks, Deen
