Coolvanillagt, Chrysler recommends the GT tires be run at a MINIMUM of 38 psi. I run mine at 41 psi. The 34 psi is for non GT's. Check the sticker on the drivers door. The GT uses high load rated tires that don't have adequate load handling at the lower tire pressures.
You should find your mileage somewhat improved by going up to 38-41 psi.
