Old 13 Sep 2005, 08:15 am
You've got it easy - with an '03 GT with metal intake, you don't have to remove the intake.
Do one wire at a time, replacing that plug as you go. I recommend you get Dielectric grease and anti-seize lubricant.
Smear the dielectric grease around the outside of the rubber plug boots that go into the head, and a little around the ceramic of the plug. Put a dab of the anti-seize on the plug threads.
Keeps everything from sticking together.
One more thing - the plugs are WAY down in the head. Find a spark plug wrench with a rubber insert to grab the plug, or use a piece of rubber hose to hold the plug when taking out or installing.
