Thread: Uneven touch up
Old 28 Sep 2005, 08:19 am
rszappa1 rszappa1 is offline
I think the whole story with using the west sand method is...DO YOU KNOW WHAT YOU ARE DOING...I have had very good results with 1000 and 2000 grit paper. I would fill the chip in slightly higher then the area around it. let it dry for a day and use first 1000 grit to smooth it down almost level then you 2000 to level and then use a little polishing compound then some wax...The end result is great...You just have to be careful with wet sanding...just a few light strokes is all that is usually needed.
