From everything I've read, the HKS SSQ BOV is the best one to use. But it does require the replacement of the uppercharge pipe with a hard pipe with the flange hole cut into it and you will need the block off plate for the original BOV location. You can get Adam's VAK or AMX's pipe. Check ptcruise.com in the vendors section for both of these guys. Both are very nice and can be had with the proper hole placement for the BOV. If you don't want to change the UCP, Bommba and Forge Motorsports both make one that goes in the stock location. I run the Forge because you can change the spring in it to run more boost without it opening. I think I would have gone with the HKS, but I had already installed the Forge when I got my UCP. The mopar unit isn't really a true BOV. It is just a plate with holes in it that works with the stock surge valve so the blow off goes into the air instead of going back into the intake.
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
