To make the bottom section fit the crusher opening you will need a grinder or really fine jigsaw, or if you want to get really frustrated, try a hacksaw - anyway, you'll need to grind down most of the fins to make it fit right. If you're going to do this, just remember the Stull has thicker blades than the E&G but less of them. I have the E&G and it was three hours to get it right. If you have never had a Stull and E&G next to each other to compare, I recommend doing that before buying either. I was on the fence until I did just that and I liked the E&G much more seeing them "in the billet".
