just my 2 cents worth but if you are not going to increase the boost past stage 1 levels then the MOPAR BOV will be just fine. The BOV's on the aftermarket allow higher boost levels to be held and reduce spikes caused by bad or weak springs. If you are going to higher boost levels you will need a boost gauge and probably an EGT and fuel air ratio gauge too. I think stage 1 is a better value then any after market chip I have seen so far.
