Intermittent problems are hard to diagnose, but the jam switches would be the first place to check. Since it's only left turns, check the right side doors and tailgate. If the tailgate light isn't coming on, the doors are most likely. Try putting a couple layers of tape on the spot where the switch contacts the door and retry. You can also try putting a couple towels on the inner door panel and pressing (gently) with your feet to see if you can trigger the problem at rest. anything that causes the problem regularly will help the diagnosis. Good Luck
