Old 19 Oct 2005, 12:56 pm
quote:Originally posted by EJIII
Are you sure whether the radiator cap has been replaced? The cap is the device that allows coolant to be sucked into the radiator from the overflow reservoir as the engine cools. If that's not it, then have the dealer put a light vacuum on the cooling system. It's possible(although remotely) that the cooling system could have a leak that allows air in, but blocks coolant from escaping. Have you noticed if the volume in your overflow reservoir actually increases?
Try to follow the KISS method as you figure this out (Keep It Simple Stupid)!
My vote, too.
Only other item would be water pump - with engine cold, start engine with cap off and look into radiator - should see water flowing in radiator.
