Thread: Now what?
Old 26 Oct 2005, 03:22 am
Mean Green Mean Green is offline
The A/F has to be a wideband and they are not cheap. With the AGP wga if you are planning to boost over 15 lbs you will need a dual stage boost controller. If not you will get bad part throttle boost (PTB). For my '03 GT the 1st stage of my bc was set at 15. No PTB in any gear. Can drive around all of the time and car will be quick. 2nd stage of the bc was set at 18 lbs of boost. If you got on it in first and second gear you got bad PTB. If you really want to get on it the trick was to start out on 1st stage of bc and when you hit third gear switch to 2nd stage of bc. The smile will never leave your face [8)]
\'05 Stone White SRT4
\'04 Graphite PT Automatic
