Old 27 Oct 2005, 05:52 pm
CruiserDan CruiserDan is offline
Send a message via AIM to CruiserDan
quote:Originally posted by PTRobert
CruiserDan,
Your PT looks sweet! I love the lowered PT and can't wait to have mine done!
Question #1: What brand of paint did you use for the foglights, and is there any guaranty that it won't peel or crackle from the heat of the lights?
Question #2: Did you install the new clutch yourself?
Thanks,
thankyou for the compliments, i love the lowered look also, and the increase in performance in the twisties.
The foglights i just used KRYLON stained glass paint from a hobby store, its the yellow color. I used the same type of paint just red for my tail lights. Ive had it on for nearly 6 months its not cracking but the problem is i didnt use clear coat on them so the paint will wear away back to the plactic. It's not hard to fix they just need to be painted again. Acetone takes the paint off pretty easily for a new paint job. But it could be remidied with some clear coat. The hartest part of that job was getting around the inner fender to get the lights out. I have to take them out and re install them anyways because my bumper doesnt line up with the lights after the body shop took it off.
If you want a more permenant guarantee there are companies floating around that sell yellow film that you put on the lense like it was window tint. Personally i like my look better. But i also have contemplated taking the lense off and painting the inside yellow so it wouldnt weather.
The clutch , i did it with my friend in his garage on a set of jack stands. Im an automechanics student and have worked in shops before so this isnt my 1st clutch job , but honestly it wasnt that hard. The hardest thing was droppin the tranny out ,and putting it back in when the clutch was installed. The only things u really have to do are disconnect shift linkage the slave cylinder and starter the battery and battery tray the distrobution block has to be moved and then bell housing bolts loosened after the engine is supportted then the tranny mount. I love the new clutch and it was worth the money and more.
If you have any more questions , i would be happy to answer.
<font color=\"blue\">Patriot Blue</font id=\"blue\"> 02 5-Spd
