You could always make a mount for right under the radio, where the middle cubby is. You'd lose the use of that shelf, but oh well. You could also pull the lower power outlet and put a gauge into that spot. Unfortunately, neither idea puts it where it is easily readable while driving. You could also go with a single gauge cup right on the steering column, which while not exactly stealth, is stealthier than a pillar pod....
