For the battery acid, you may in trouble as it might of eaten the clear coat. Take some kerosene to remove the acid spots, you will know right away when you take the gooey stuff off what condition the clear coat is in. if it is etched, its body shop time. For your rust, take the eraser end of a pencil and put a small piece of 2000 wet sand paper on it. Gently rub the rust spot in that area. that should take care of it, use a little touch up to blend it in. Gary
