Thread: Fog Lamps?
Old 06 Nov 2005, 08:22 pm
Hooligan Hooligan is offline
quote:Originally posted by philpatton
I have read where several people are having trouble with the fog lights and the multi-function switch.
I bought my fog lights off of e-bay and plan to run new wires and put toggle switches where the silly coin holders are.
How do I remove the “blanks” that occupy the space where the fog lights go? I’m sure that I’m going to have to jack the car up, remove the tire and inner finder. Am I correct or is there an easier way. Use ramps to raise the front end. You should be able to remove the blanks as I think only a screw holds them in. The only thing that gave me a problem was running the wires thru the fire wall. I removed the clutch plate and drilled a hole thru it, it also helps IT you have small hands as I couldn't do it, my wifes hands were able to hold it while I tightended the nuts. I made sure that I used a tube of sealant to close the hole and give it some support, )I used silicone sealant) The other thing to watch it replacing the flasher control from old MF switch to the new one.
By the way does anyone else think that having to take off the tire to replace a halogen bulb in the headlight something that is reminiscent of some of the silly engineering ideas that GM had in the ‘70s?
[8]
2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals.
