i would run it after the first change of 3k or in your case you should be fine. the reason is this on a new engine like say a race engine if you run synthetic oil right away you can run in to ring problem with them not seating right because the oil is too slippery. i have a big block chevy that is close to 900hp and when the engine gets new rings it runs on the dyno to seat the rings first then gets synthetic oil. your rings should be seated properly by now.
