  #16 (permalink)
Old 09 Nov 2005, 01:47 pm
fritz_t_coyote fritz_t_coyote is offline
quote:Originally posted by jcmhead
Try using the mix setting feet and window or where it doesn't allow you to turn it to recirc. I can't stand it either it robs power and you know the car doesn't have any anyway!!
Note that the AC compressor cuts-out at wide-open-throttle.
so just floor it and you'll have power.
also the ac compressor should only fire up in defrost mode when ambient temps are 'warm enough' that humidity in the incoming air is a problem.
There is a hack out there where by clipping a conductor path on the hvac control panel you can keep the AC from running in defrost mode unless you purposely set the fan to the 'ac' side.
www.visualizecommonsense.com
