So you are saying it's a direct bolt-on other than the sensors?
Did you notice any loss of power at the lower RPM's? I'm thinking Chrysler kept the TB smaller on the 5-spd to increase torque at lower RPM's. The automatic wouldn't need to do that since the torque converter is a torque multiplier as you start moving the car from a stop.
Deen
