Old 30 Nov 2005, 02:38 pm
Wicked_PT Wicked_PT is offline
I like it. Not sure it was worth the money. Although now the price has droped dramatically. I bought mine originally for $3500. Now they (J.R.) has knocked off $1000! Makes me mad! There is a noticable difference in HP and torque. I had allot of other mods to begin with so it was not to dramatic. I love the pick up and the way it keeps pulling when you step on the gas. I talked to the guys at J.R. and they said they never had this problem before with the false code/check engine lite coming on. They have one instaled on a 01, 5 speed at J.R. But I seriously doubt they drive it every day with the troutle body wide open in 5th gear? I had my local dealership install mine. Add another $950 to the cost.
Dealership said the code was false. It kept saying it was the injectors that were bad and the car would misfire when it was in 5th gear. Dealership looked everything over and could not figure out the problem. The superchagrer came with it's own computer that pigy backs the stock CPU. The dealership said they thought that the computer "Power Card" (pigy back) was bad. So J.R. agreed to send out a new one. In the mean time I had the dealership sauder the wires together instead of using the plastic "t" clips provided for a better contact. It seemed to fix the problem but it only lasted for a few days before the check engine light came back. By that time we had sent back the new Power Card to J.R. That's when we(me and the dealership) decided to replace the spark plugs with the PT TURBO coper champion plus plugs. These are a colder degree spark plug and are able to hadle higher temperatures generated by the superchager. This seem to fix my problem. It lasted for about another month before the code came back. But this time it di NOT Misfire at all. I took it back to the dealership to have the code cleared, this time the O2 sensor said it was runing to lean. It needs to be richened up some how. The Power Card is suposed to map the air-to-fuel ratio so you don't have to worry about that type of stuff.
That's when I realized the dealer probably never disconected the battery when they installed the new spark plugs. I think I solved the problem by just disonecting the battery for a few minutes and then re-conecting it. It's been 2 months now and it works fine so far. Just wanted to know if anyone else had this similar problem. Makes me wonder why the supercharger has been reduced in price also?
