Just keep in mind that it won't matter how big your T.B. is if your intake manifold insides don't match. In other words, if the insides of the intake manifold are not bored out and ported, then the nice wide T.B. that you are adding is soon brought back down to the narrow air flow of the intake restricted size. And if you have a plastic intake manifold, then you will not be able to bore and port them. It would have to be the original cast iron type.
Besides, anything with a diamiter biger than 60mm is going to be to big for the end of the manifold where the T.B. is attached. Then you will have overlaping.
