quote:Originally posted by Cal Cruzer
quote:Originally posted by Topless in Cali
Just make sure you put in the sensors from the 5spd otherwise it will throw codes. It makes [8)]
Did you have to calibrate the TPS when you switched it over to the new TB or is it a one position installation?
you would not have to caliberate it one way install. if your get on that comes wiht the sensors on it you don't have to switch them over. he had to because he had a bad one on the new t-body
