I have 18's in the front and 20's in the rear. I only have them on in the summer time and take them off for winter. I have used my wheels for 2 summers including this summer that has just passed and all of my tires are wearing evenly. I didnt rotate them at all and I have No uneven wear or nothing. As far as tread directions go, My tires can go either direction(they are unidirectional). I have the TOYO Proxes 4 tire and this is a great tire with superb grip, STYLISH TREAD, even wear,and quality. No problems to this date. Actually, These low-profile tires that I have are rated All-season tires believe it or not, but I still dont run them in the winter time because of all the stupid salt on the streets.
Appearance
Aggressive unidirectional tread design.
Unique "W-shape" tread pattern.
Modern high-image sidewall design.
Unique "4" logo on tread elements.
Wet and Dry Handling Compound
"Generation S" silica-reinforced, high-grip tread compound.
Unidirectional tread design High angle tread grooves to evacuate water.
Paired shoulder blocks to increase cornering grip.
Curving center rib to enhance directional stability.
Steering Responce
T-Mode Design Technology.
Hard bead filler compound.
Two full-width steel belts.
High grip tread compound.
All-Season Traction
Unidirectional all-season tread design.
"Multi-Wave Sipes" in shoulder blocks.
M&S rated.
Smooth, Quiet Ride
"Multi-Wave Sipe" for reduced heel and toe wear.
Variable-pitch block tread pattern.
Jointless edge and cap ply construction.
Jointless bead wire.
Durability and Tread Life
"Generation S" silica reinforced tread compound.
UTQG
Tread
Trac
Temp
-300
-AA
-A
The Proxes 4 is Toyo's new all-season ultra-high performance tire. It is designed primarily for plus-fitment applications on sport compact cars, sports sedans, and coupes.
2002 PT Cruiser Touring Edit.(Stone White)(148.2 DB) --Rear match Tinted front windows, 20\"+18\" Limited 800 rims+ Toyo proxes 4 tires;\'20\"\'Chrome DUB badges to clarify, 6000k Polarion HID kit, silverstar foglight bulbs, Carriage Works polished Billet grille, Mopar Chrome fuel door, APC Euro tails + clear reverse lenses+ strobes, headlight strobes, Streetglow G.S UB kit, Ps2,2 Clarion 5.8\" headrest monitors, navigation system, 2 12\" Infinity subs with 1000 Watt Kenwood Amp/custom box., and a Shorty antenna + Chrome base.
