Old 07 Dec 2005, 02:22 pm
2step 2step is offline
PTlimamix....
You must have the steering wheel control buttons. Most PT Cruisers do not have that and I haven't seen that personally myself yet. Those are the only radios with the shut down delay. From what I understand about what that is for is so that when you turn the key to the "off" position, you can unload CD music disks from the unit for 45 more seconds or open the door. I understand that you say the "radio" now shuts off immidately with the key and that is not as it should be. But have you tried to unload a CD also, with the key off before you open a door? If that no longer works, your dealer service department will have to fix the problem.
Good luck and welcome to the forum.
