Remove the single screw at the bottom and sort of pivot from there while also pulling out at the top. There are a couple of spring clips near the top that hold the lens at the top. A quarter turn on each lamp socket is all you have to do to pop those out. One minute per side and you're done.
Edit added...It's possible to get water into the lens if a very high pressure stream is directed at the screw hole at close range and held there for a moment. That hole is not sealed and is meant to be a drain for minor condensation.
