First of all, stop shouting. (ALL CAPS!) It's rude. Secondly, if you put Dexron in your transmission, you may as well start saving your pennies now, because you will be buying a new trans, and it won't be covered. Why do you need to "top it off" anyway? It's a closed system, and if you need fluid, there is a larger problem, and you should take it to your dealer and have them look at it. If it's not leaking, what's the point? Either way, USE ATF+4! ( I know, I was shouting)....
