  #15 (permalink)
Old 16 Dec 2005, 05:56 pm
rszappa1 rszappa1 is offline
A little tip on those so called sealed batterys. If you look close there is usualy a peice of plastic that you can pry off to get to eash cell. I have always every so often checked the water level and if needed added distilled water to the level. Most failures happen because over time the level start to drop on one or two of the celss. A little water will keep the battery lastind longer...
