Save Yourself money and make an extra key and hide it in the steering column near the ing. swtich. You might have to play with it a little, but it works I did it. Also go to the12volt.com and you can get info and wiring diagrams. There is alot of stuff there to help you with the install. I used it myself as well. The door tiggers are funny but there is 1 wire on the pass. side that will work the lock and unlock if i remember right. You do have to use a relay. There might be 2 wires though I don't remember I did it 2 years ago and never had a problem.
Ride Hard, Ride Fast, but Ride Safe [8)]
http://www.cardomain.com/memberpage/529247
