quote:Originally posted by shil
I've used the Mobile 1 synthetic in another car and liked it. Haven't yet changed the fluid in my 5-speed PT.
Once you do find the filler plug, make sure that you can get it open BEFORE you drain the old stuff. Would not be good to drain the tranny and be unable to fill it again.
Yep, I always make sure I can open the fill before draining it. Thanks for the reminder though. ThatÂ’s one of the reasons I want to know where about the fill plug is, so I can see how easy the job will be.
I will probably end up using Mobil 1 synthetic unless someone else knows of better oil. Does anyone know what weight the stock transmission fluid is?
Thanks,
Matt
