quote:Originally posted by bluewasp
Have reset several times, light returns each time after a few miles.
Are you sure your Cat is not installed backwards? It is an easy mistake that some people make. There should be an engraved arrow on you Cat and it should point towards the rear exit of the exhaust. If the arrow is pointing towards the headers, then it need to be flipped around. You O2 sensor could be on the wrong side of the Cat if it is installed this way. But it is posible that your O2 sensor is burnt out as well. There are 2 O2 sensors, one on the header, and 1 on the Cat.
