Old 07 Feb 2006, 08:49 am
quote:Originally posted by ruzz1
How do u gap the spark plugs to 0.04? I just changed mine at the dealer and assumed that they will install with the correct gap. I hope they know the correct gap. They use the normal recomended plugs as per chrysler service book. is this sufficient?
Any auto parts place will have gapping gauges - usually by checkout - I use a disk that has a "ramp" around the edge - the "ramp" is marked with various thicknesses.
To widen gap, I push the edge of a piece of wood under the lip of the top electrode - nearly parallel to the plug ceramic - NEVER pry the top wider by leveraging on the center.
If car runs okay, I'd say you're okay.
To close gap, I tap the top on a block of wood.
