Thread: HELP
Old 11 Feb 2006, 02:16 pm
CREWZIN CREWZIN is online now
quote:Originally posted by Aquiles
The Pt is aligned and balance I will try to rotate the tires but like I said slightly vibrate when accelerating on initial drive off then
then as the speed increases the wobble/vibration is not apparent anymore
This is non turbo 2006
Just guessing, but I wonder if you have something loose or broken in the steering or half shafts? All front wheel drive cars have torque steer on initial take-off, but hardly noticeable under normal conditions. If something from the factory wasn't tightened down or has broken, it might exaggerate that torque pull, but then again, you would think that you should feel it at other speeds. [:I]
