I am not sure, but I would image that as long as it was only the rear, and the rim gained more width towards the outside ( the 2" of extra rim width goes mostly away from the car not inward) Then it might be ok. The front might be more of a problem as the inner clearance during hard turning might cause rubbling. You might have to go staggered. Someone else might know more.
You know that your rolling diameter is going to be larger right. A stock 16" rim with 205/55 tires are the same approximate rolling diameter as a 17" 245/40 size.(around 25") You are adding an extra inch going to 18"
I run 225/50's on my stock 16X6 inch rims and am lowered 2" and have had no rubbing yet that I have noticed.
2004 Platnium Ltd Ed. Turbo. Stage 1, 06 composite intake, Voodoo III MBC, Custom axle back straight pipe, Spectre ABTT, Magstar Race wires, K&N filter,Springtech 2\" drop, Silencers removed, iridium plugs. Best ET 14.224 @ 97.6 on street tires
