Old 20 Feb 2006, 08:36 pm
CREWZIN CREWZIN is offline
Hi,
Gonz was just trying to point out that doing a search on the forum will bring you all the information you would need, but if you don't care for that way, I'll start off by saying the Non-turbo PT wasn't built for speed. If you want to bump it up a little bit without breaking the bank, a free flow air intake, and less restrictive exhaust. Decent plugs at the correct settings and better plug wires will keep it at optimum performance.
Lowering the center of gravity by the use of lowering springs and an upper strut bar will help with cornering, road holding and straight line performance. As soon as you can, get rid of the stock Good-4-A-Year tires. There's plenty to choose from.
Then you get to the good stuff....plenty of BLING, upgraded wheels, pin-stripes or flames......now your talkin!
