Have you checked for any codes yourself? Put the key in the ignition, turn key on-off-on-off-on (not start-off-start-off-start!). Any codes will display in the odometer window. if all you see is "done", then there are no codes. Report back to us....
2004 PT GT -Stage 1, K&N Drop-In, Airbox Mods, \'05 Composite Manifold, AMX TTAB, NGK V-Powers at .040, Magnecore KV-85\'s, Mopar BOV, BTG Strut Bar, Mopar Rear Sway, Drilled/Slotted rotors, Hawk HPS Brake Pads, a few visual Mods, a coupla Road Runners, and a Partridge in a Pear tree......
