Old 22 Feb 2006, 04:09 pm
Topless in Cali Topless in Cali is offline
quote:Originally posted by rszappa1
and unless you go to a drag strip and get the official time...you are not going to feel 5 to 8 hp....plus your plugs become harder to change..
It depends on how much your GT is modded. I noticed a big difference when I started cranking up the BC after installing the plastic manifold. At higher boost, 18+, the metal intake manifold just doesn't flow like the plastic. And to get to the plugs, it just takes a universal joint on your plug socket!
The only advantage I see with the metal intake is that you could have it honed out to larger holes than the plastic, but it is a lot more than $65 for that and unless you're running a BIG turbo, I can't see spending a few hundred bucks for extrude honing and polishing
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
