Thread: Wish me luck
Old 23 Feb 2006, 11:55 am
Couple of predictions:
100% sure - Brake light is because your pads wore and pistons in calipers are out a little more, causing brake fluid to drop - when you hit gas, fluid will "slosh" & show low fluid. You can either add some fluid or get ceramic pads & get rid of brake dust at the same time.
90% sure - inner shoulder wear on a tire - alignment.
50% sure - shimmy - balance/alignment.
Not sure - clunk - could it be the wastegate closing when you take foot off gas? I see you have an intake - when I put on my K&N intake, I was amazed at noises I heard.
Let me know how I am with my "predictions"....
