quote:Originally posted by rszappa1
Hooligan...you might be looking back because it is the same old Auto..Tranny.....with all of the problems...
Actually, I've read that there's a pin in the auto that could work loose, and when it does, it eats the tranny real quickly. Supposedly, this pin was redesigned so it won't work loose as readily, I think in '05 trannys on......
Still problems with clutch packs leaking/failing.
