Old 27 Feb 2006, 02:18 pm
fritz_t_coyote fritz_t_coyote is offline
quote:Originally posted by Ctown
Planning on getting the Woox but wondering how difficults the installation? Is it just tapping some wires into the back of the radio or it req remove of chairs carpets anc dash etc......
I mounted my woox under the drivers seat.
1_ Instead of drilling holes for the mounting brackets,
I found I was able to loosing the front drivers seat mounting bolts,
With the mounting brackets on the woox, slip the mounting brackets under the front cross-brace where the seat is bolted to floor (trapping the tabs of the mounting brackets between the seat base and the carpet) and re-torque the seat mounting bolts.
2- Signal wires:
After removing the center dash, radio and =center console= (a real PITA) I simply spliced the woox cables onto the radio harness
*Note that I found an unused socket on the factory harness that connected to the 'antenna signal' pin of my factory radio (according to the pin-out diagram decal on the radio itself). This I used for the 'power on signal' lead for the woox. It works great for switching on the woox whenever the stereo is switched on.
3- Power: I ran the woox power lead to the battery + terminal. This required poking an extra hole in the rubber boot around an existing bundle of wires going thru the firewall.)
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
