Old 27 Feb 2006, 02:57 pm
strangelove strangelove is offline
Oh that's whats going on, really interesting. Thought I was having a nightmare or something. For some reason I thought he was injecting water into the manifold. So let me get this straight, a bleed line connected to a solenoid tied into the waste gate actuater. When the water injector is triggered it takes air from the wga and adds it to the fuel mixture. The water injector isn't injecting water it is injecting air creating more boost. These wires tap into the manifold where air is added to help cool the air before it passes onto the cumbustion chambers. Am I close? Question: So what is a water injector and how does it cool the charge or add boost? Is this a modification of an existing part, or is it a bolt on application, and most important why are the wires yellow?[B)]
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
