Old 08 Feb 2003, 02:16 am
2sb 2sb is offline
The two bolts on the bottom of the strut set camber. If lowering pushes it too far off, places like Moss sell offset camber bolts to bring it in. Negative camber wears out the inside tread of your tires. If you corner too fast (bob), you wear out the outside edge so negative camber may make your tire wear more evenly.
Edited by - 2sb on 02/08/2003 00:17:51
