quote:Originally posted by Ctown
quote:Originally posted by Carchrism5
congrats on the new setup, did you install all of it already? if so how did you cut out for the tweeters?
Yes I did. It took me around 7-8 hours total. I took my time. One thing I want to warn you is that you may not want to replace the dash tweeters. The Tre-sounds thats coming out of the new tweeters mask the door speaker. I'm not sure if they draw power from those door speakers too. I swear that after installing the tweeters the door speakers sound weaker. They are from the same line. The upside is that you will hear small detail or crisper sharp sounds going going left and right. However still I rather have those sound coming from the door speakers that those tweeters.
I started with a saw to cut open the opening and I find it takes aout of effort. I ended up using a drill with a small wood drill bit. If u have a good drill bit it works like a saw if u press it really hard in the right direction. The finish work looks messy but no one can see it when I put the cover back on
2001 Ltd Ed. Inferno Red PT, many mods, many more to come.
