Old 03 Apr 2006, 06:48 pm
Hooligan Hooligan is offline
Remove the Air Intake Manifold (I assume you have a NA), hold it up with a bungee cord. Remove & replace plugs (gapped at .04.) use antisieze on plugs, and dielectric grease on both ends of the "boots". Torque plugs to 13 ft lbs, torque intake manifold to 105 inch lbs using the following pattern, all snug then:
5 3 1 2 4
Good Luck!!!
