hello - i had a chrysler lhs with this same sensor problem/code. replace the sensor. it's one small bolt and a connector. i got my sensor at my local parts store (kragen) for less that $50. after you replace it, either reset your check engine light with your scan tool or disconnect the battery for 20 minutes. let me know if you need help locating the cam shaft sensor. i have a pt dealer service manual and will look it up for you.
 gt model, aftermarket air cleaner, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim.
