I had a similar problem with my old Spirit.While initially accelerating the front end would wobble then at speed would smooth out.It was a driveshaft tripod,this part keeps the drive shafts from moving longitudinally. You should take the car in ASAP if this the problem you are going to only see a lot more damage from whichever shaft is shifting.
Then again,hope your lugnuts are tight
