Old 19 Apr 2006, 01:47 pm
santacruzer santacruzer is offline
quote:Originally posted by justine311
I installed an extra ground wire from the Neg. batt. terminal to the frame but the lights still sometimes dim for a second when the fan is turned on, hit the brakes, etc. it does not do it as much since i installed the extra ground but should i just keep installing a few more? Is there a better spot than the firewall to add a ground that would help the lights?
CREWZIN sent me a great picture with 3 spots and I mounted it to one of the bolts on the computer on the firewall. Once again should I keep putting more on until the problem disapears?
Try replacing the factory ground on the passenger side that goes from the back of the engine block to a spot near or on the motor mount.
