Thread: A/C
Old 24 May 2006, 03:58 pm
CREWZIN CREWZIN is offline
Stirfry,
Don't go away mad. It's just the way you worded your post (R something kit) that getting technical seemed like it wouldn't do any good. By the way it's R-134 that 99% of the cars are using). If your positive that the combination in your system is right and the pressure is correct, that leaves out one of the big possiblilities: the high pressure switch. You can't see the compressor in the PT, but can you feel it coming on or re-cycling? Here it click on and off? The pressure has to be just right or that switch I was referring to, won't let the compressor come on.
